K
Ken Barlowned
I know that the drain issue has been covered in various threads before but mine is slightly different & I’m looking for some clarity hopefully..
I noticed today that the small runner hole on sliding window is draining to the inside of the van. Feeling about with a pice of wire it seems that the bottom part that directs the water to the outside is flapping about underneath and needs to be clipped back upwards I guess. Is there a way to do this? Currently this is not causing Major problems as my sliding window seals are clean and good.
But! With winter approaching should I try to do something to fix the under side of that drain hole? I have been pouring water over the windows and the runner stays dry so should I just leave it be, or get it sorted before it all goes wrong?
