stevetrent
- Messages
- 9
Just rigged up close to 4 metres of LED lights under our factory fitted awning. Testing them over the weekend at the Just Kampers Open Weekend and really pleased with the result.
They are similar to the Fiamma LED kits but loads cheaper, costing around £35 in total for the LED strip, cable, 12v plug & double sided tape. Along with around a couple of hours of work measuring up, soldering together and then fitting.
Took a little bit of consideration making sure everything fitted when closed up etc but so chuffed and well worth the time and effort for a sweet finish and one less thing to put up when setting up. The cool thing is that you can also turn lights on before opening the awning so you have light to set the awning up in the dark as well!
Will try and post a photo if I can.
