R
Rachael
Hi I want to use 200W PORTABLE solar power panel to extend time off grid, we need this for the fridge and heating.
We have a 6.1 Ocean.
Is there anything on the market that allows you to just plug the portable solar into the 12V to charge the leisure battery? Or plug and play solution?
I don't want to be using crocodile clips or changing electrics myself, I also don't want to invalidate our warranty.
The only 'plug and play' solution i have found would require buying a power bank such as the Delta 2 which we can charge with solar and then plug then into to the external hook up socket on the van as a way to 'charge the lesiure battery'. This would be an expensive work around! Surely there is a simpler way?
Thanks for suggestions
