Plywood visible in gap between cupboards above rear doors
GC-DUB
GC-DUB
Brighton
Grand California 600
Has anyone noticed this before? I'm wondering if it's the result of a VW dealer rear break light replacement! The gap on the right is worse.
Is it missing some kind of internal white sleeve to hide the plywood carcass?
Yes. Brakelight done a couple of years ago. Like you I first noticed after that work was done probably because I was looking closely at things. I reached out to a fellow GC owner at the time to check if it was as a result of the work but theirs was identical even though they had not had the brake light resealed.
I've just been to look at mine - I've never noticed before that you can see the ply in the join. Mine hasn't been taken apart for brake light fitting - and it might just be the photo, but I think my factory fit is better than the dealer fit.
