Loz
I have read a few threads about power and running fridges in a beach etc so I thought I would post up a small DIY project I did a couple of years ago to allow us to run a fridge and freezer in our Touareg whilst wild camping on our overland trips.
The unit is basically a standalone unit that has an AGM leisure battery, a 25A CTEK marine charger and CTEK D250 split charge unit and a NASA battery monitor.
Enclosure is a Stanley FaxMax 20" HD toolbox.
Next was to make a stronger base plate from phenolic coated 9mm board (Hexagrip)
Then mounted the Ctek 25A charger and the Ctek D250S split charge unit. MXS25 D250S
Then fit the Battery and ABX AGM 31-800 90AH with M10 terminals ABXAGM 31-800
Then installed the Nasa Battery Monitor BM-1 BM-1
It now has:
The unit is capable of running the Engel freezer at -18 for 60 hours.
When camped the unit and freezer can be moved into a driveaway tent and can be connected to EHU with a suitable extension cable.
You ca also connect 2 solar panels to the small jack plug sockets above the monitor as the Ctek D250 has built in solar panel controller.
It now has:
- 2 12V accessory outlet for the Engle & Waeco Fridge
- 2 12v din sockets for led striplight and 1 spare
- 1 dual 2.1A USB outlets for charging ipad and phones etc.
- 2 solar panel inputs
- Nasa Battery Monitor
- 25A Ctek Charger
- Ctek Split charge unit
- passive cooling
- 90AH AGm Battery
- Fuse panel for each circuit
- 16A mains hookup lead
- 60A Anderson lead for connecting to Vehicle Battery
