Kitesurfer
kitesurfer
- Messages
- 80
- Vehicle
- T5 Beach
Any one experienced a burst power steering pipe, this happened to me last week, as soon as I realised something was not right, I stopped checked the reservoir to find fluid below the low dip stick mark.
Phoned for break down Green Flag & got taken to the VW Garage to get repaired.
I was told that I had run the power steering pump dry & required a new pump & new pipe work.
I don't think it was run dry if there is still fluid in the reservoir ?.
The pipe that burst runs form the pump to the steering rack, this is a steel pipe bent in a S shape with a solid fixing bracket, with rubber tubes on ether end that connect to the pump & steering rack.
I assume that the rubber pipes are to take any flexible movement out of the connection.
My thoughts are that the reason the steel pipe broke was due to it being solidly fixed with the substantial pipe bracket, this has then put strain - metal fatigue into the steel pipe that has eventually cracked.
I am going to contact VW customer care to check if this is a regular problem & maybe a design fault
PS tried attaching photos to this thread but can not figure out how to ?
Terry
Terry
