Marmaduke’s Van
Good afternoon all.
I’ve just changed both leisure batteries in my T5 Ocean and got a good arc/spark when I reconnected the rear battery.
Oddly the wire that sparked wasn’t one of the terminals but what could be an extra wire from the negative connector to the battery clamp bolt. There was no spark when I connected the negative terminal bock to the battery, only when I connected the additional wire.
I’m thinking that the main negative wire isn’t connected properly to the vehicle body if the extra wire sparks and also that there is a significant load/leakage even when everything is off.
Any one able to offer any wisdom?
Many thanks
Many thanks
