Little owl1963
There are 2 x Levers on the left an right hand side , which are to release or locate on the Studs either side .
3 studs on the left hand side , 2 studs on the right hand side .
Push forward to locate and pull back to release with both levers held back .
The Loop allows ratchet arm system to raise or lower the headboard , which should be independent of locating studs ??/ levers .
Why is it then if release loop is held on too and not let go , the system comes off the side studs ??
Is this a bad design fault from vilkswagen ??
