As has been explained above. If you don't spec the Comfort mattress at purchase then you get a thin foam pad to fit the rear shelf, which if set on the higher level provides a flat surface when the bench seat is in bed position.May be a stupid question, but why is there two height holes in the boot floor, bed base ? I can understand to get a bit higher boot space , but surely then your base mattress has a hump and is un comfortable for sleeping
If it's the VW Comfort Mattress it will be in 3 sections and the rearmost section, with a corner cutout, is twice the thickness of the other two sections.Ours is a single mattress and the rear is set on lowest position and there is no step ( i think ?? )
