TripleBee
I think, to get your answer, you'd better go check your van, and let them show the problem to you.
If your disks look like this:
You'd better have them replaced.
If they look like this:
It's disputable, but not a fail imo.
Anything in between is disputable.
Yes, one (1) brake pad has a sensor, the near (right) side inner pad. But if any of the other 3 reaches the minimum thickness, then all 4 pads needs replacing (1 set = 4 pads).
I had the two inner pads worn, and the two outer halfway. Of course the check brake pads light went on, as there were 2 pads almost completely worn, one with the sensor.
And please don't ignore your safety on tyres and brakes, because they are the only way to stop the van and to keep it on the road.
New disks means new brake pads. Don't put back used brake pads on new disks.
You could ask them (VW?) to put in ECO parts. They are much cheaper. But I think this is only possible on VIN number if the van gets 5 years old.
But if the part numbers are the same as my old 2010 van, the original parts number of the brake pads is: 7E0 698 451 B (was €153,67)
ECO: JZW 698 451 K (was €72,24)
Brake disks: 7E0 615 601 D (was €107)
You can have an eco set of pads and disks but that is about €300. So you'd better go for ECO pads and a set of original disks.
