Rear windscreen washer leaking
jts46
jts46
Derbyshire & Lot et Garonne
T5 SE 130
Leaking between exiting body of van to the rear washer jet. I have established it is leaking into the rear metal part of tailgate panel.
I need to removed chairs and all fittings to gain access to the pipe or can i remove the pipe without removing all the panels?
What is the diameter of the corrugated water pipe?
Any help suggestions for this repair would be grateful before i start the repair.
Hi John , taking of the trim that holds the campingchairs is a pita so everyone says even dealers hate this ....
Did you look at the partcatalog diagram ? May help ...
Seems Paul did the search allready...:thumb
The washer pipeline does not seems to appear on the diagram...
Removing all that trim is a looot of work
Anyone know the routing of the rear washer water pipe after exiting rear of van?
Did you get an answer , i have a leak above the rear wardrobe at the most rear of the van , can see water rushing out but cannot see were from
