Replacing rubber seals floor cabin T5
bmassaer
bmassaer
Please Select
Hello,
In our VW California T5 2007, the rails in which the rear bench slides is protected by rubber sealings. Can these easily be replaced?
Thank you
Bart
Depends if the rubber can be pulled out of the alu-trim or the whole alu-trim needs changed .
Take a look in the parts catalog and see if only rubbers are availeble and have a part nr. , it might give a clue.
Ok, thank you for your answer. In that case, I will wait for a while and try to protect them!
Bart
