rippers
Is there a reversed polarity indicator in the Cali Se when plugging in the Hook up lead?
No you need to buy a polarity tester and check yourself once hooked up
Or make up a short lead that you reverse wiring
but would would need to know whether wiring was reversed first as its random across France and Spain.. some are, some aren't.
You could end up reversing a socket that doesn't need it and be back where you started
I think everything still works but anything plugged in remains live at all times (I'm not an electrician btw). I think the risk of electric shock is small but I always have a reverse wired lead and a tester in the van when we go abroad.Okey dokey will get one ordered, every other site we visited between france and spain was reversed. We had a indicator on the hook up lead we used to dangle thou the window in Beach.
silly question but being a two pin continental lead if it it reversed can you just plug the lead in upside down on the campsite oulet??
Also what damage can you/what effect will it have on a California SE if it is reversed? Do the batteries not charge? power inverter/fridge/heater not work?? or does it just have effect on what you plug into the 240v plug socket inside? Pretty sure most modern appliances can be reversed without effect?
Any advise would be great, thanks in advance
The RCBO in the van is10A overload, it is quite possible to have a small appliance with a 1A fuse in it. Depending on the fault current both fuse and RCBO could operate.I accept that, but any fault that is enough to blow a fuse in the item would also trip the RCBO in the van. In fact the van protection is more sensitive than a fuse so you should never get a fuse blowing, the van will trip instead.
On reversed polarity the fuse would be in the neutral. The appliance wouldn't know the difference. By the way, I don't carry a polarity tester, I'm not overly concerned, the protection in the van is adequate.I can't see reversed polarity being a problem on anything I'm likely to plug into the van.
I think all my camera/laptop/phone chargers use a 2 pin figure of 8 connector into the actual device on the opposite end of the lead to the plug, so they have a 50/50 chance as to which side is live. the only thing I can think of that might be sensitive is an old style TV rather than a flat screen.
I might be wrong but I believe the circuit breaker fitted to the van is twin pole & therefore works whichever way round the van is connected.
