Reversing camera.
Automatically switches the rear camera on a soon as you go in reverse doesn’t matter how bright it is you will see it in the head unit
If it is an original camera, the fitter of the aftermarket radio might not have known about the camera, and just didn't connect it?
Try to plug out the unit and search for a connection between the unit wire loom and the vehicle wire loom for the camera?
Some pictures might help then.
(Well, we might help if we see the pictures)
It was a vw van, so was probably fitted by vw, Got to go back to dealer anyway couple of bits not right
Is the parking camera standard on the 6.1? I didn't see it on the options list...
Aggiungerei che il mio è stato montato in fabbrica.
Problema simile, cali Ocean T6 del 2018 con traino originale, è possibile che ci siano già i cavi predisposti x la fotocamera? Nell'unità principale credo ci sia già il connettore e ci sono cavi che partono. Ma non ho nessuna camera sul portellone.
Grazie a chiunque può aiutarmi IMG_20241013_144044.jpgIMG_20241013_144114.jpg
