sebking
Hi all,
I swapped out my RCD310 for an RNS315 from ebay. It came with an antenna and popped in pretty easy. Worked well to start with but now getting very intermittent GPS. I've not coded it to the MFD (need VCDS) but thought it should be fine.
Ive repositioned the antenna and it's still very flaky, the vendor says that the lack of coding may be causing the issue?
Also looking at the over VW forums there is a lot of mention about removing the VW antenna if that is fitted, I'm guessing there will not be one if a Nav was not specced from new? Not even sure where to look for it either!
Any ideas and anyone with VCDS near Oxford?
Cheers
Seb
Cheers
Seb
