briwy
If I load a speed camera database onto the 510 does it give a warning flash or sound on approaching a camera or does it just show up as a POI?
If there is no warning sound/flash then it's not a lot of use as you would need to be looking at the satnav all the time.
Also, I get the impression that loading any new POI database onto the 510 will wipe out the existing POIs. Is this correct, if so is there a way of incorporating the the existing with the new?
Thanks for any help.
