CYCLOPATH
My 2015 T5.1 SE had the roof recall done last month.
The tape was applied and the rubber seems to have been glued back on.
But I noticed that they had torn the rubber near the drivers door. Not enough to effect its sealing.
The VW garage say they will replace the seal. BUT. Now it is glued on, how will they remove it? Could the do more damage using heat or a scraper?
I understand there was no corrosion
Am I best just to leave it, may be just silicone the gap?
I understand somebody here has had similar problems and the seal replaced. How did it go
Thanks for your thoughts
