Roof window
Sp0_0k
Sp0_0k
T6 Beach 4Motion
Are there technical limitations to adding a window on a tent roof? Surprised there is no such option.
Could be great to sleep and look at the stars.
I'm sure it could be done with some expensive and strong materials because the one piece construction makes it very strong and cutting a hole would require some significant strengthening.
Exactly the reinforced hole will make the roof even sturdier. All cars with such windows have more strength in the roof.
But those cars with a sunroof have the roofed fixed front/rear and both sides. The California roof is only held on by the side struts of the lifting mechanism. It might be stronger when in the locked down position, but when elevated in windy conditions?
Writing as someone who knows nothing about the strength or otherwise of elevating roofs - l just press the button and up or down it goes - the Wildax Pulsar has an elevating roof and skylight windows.
Agree. A skylight, projecting above the roof line making it very difficult to cary anything up there on roof bars etc: and raising the height over 2m , which restricts your parking options.
Btw what is precise height with an awning? I see that it sticks out a bit higher.
The roof is also curved upwards in the middle. With a straight edge across the roof I measure 1997mm, with VW awning. I regularly use 2m height restricted car parks with no problems. Standard suspension and 17" wheels.
The Wildax window for those curious like me!
Most people take extra measures to keep the light out so as not to be woken early in summer, so not a good idea for me.
One of these and a couple of tubes of mastic, everything should be OK.
Not sure about the roof paint warranty:Nailbiting
The Wildax looks ok, but it must be a pain having to hold the ceiling up.
Yea bet that window influences motor power as well.
reserves
reserves
California Dreamer
California Dreamer
California Dreamer
Vincent123
raynormor
raynormor
2CV67
James
James
