CaliKingMK2023
Hi All,
Quick question. I have solar (provided by Roger who is awesome btw) and an Ecoflow River 2 Pro. The Ecoflow currently sits in the bottom of the right hand wardrobe above the safe, but for ease (and to avoid using an extension), I’d like to move it into the bottom half of the cupboard under the hob.
Easy enough I hear you cry, but I would like it to still take the ‘load’ charge from the MPPT. Is there a route that I can run the cable through? I was thinking of routing through the area from the leisure battery is and under the fridge into the opening where the grey water valve is, but is there a blockage there or is it open enough to feed a cable through?
Thanks in advance!
Thanks in advance!
