It turned out that the fuze had blown on the leisure battery…!!! Changed that and the EAC works like a dream now … just tried it at 400w … not sure how much one can push the alternator though ?That’s the key, to set the voltage at 13v. I think the EAC does drain the leisure battery quicker than it is charged though. Although that’s only anecdotal.
I assume you can’t just put a long reach socket on it and undo?
I think it’s actually welded to the chassis. What looked like the head of a bolt has 8 sides. In the end I have cut it lower and it’s still usable.I assume you can’t just put a long reach socket on it and undo?
I've had the AC installed for about 9 months, and I'm constantly observing the behaviour of all related devices. I have my AC set to 13V, so it should never drain the leisure battery when the car isn't running.not sure how much one can push the alternator though ?
Hi all ! I’m new here but would really appreciate some advice.This is how I installed it as a test today to the rear hose battery in a Cali Ocean T6.1 2023. You how know this, does it look ok? Everything seems to work fine, charges with 800W at 13.5 V (after update of EF and EAC) and reverse charges as well. I guess it will only charge the rear AGM battery? I wonder if Calis battery management system will get confused?
Yes, and the smalll electronic thing on the -pole connected with a cable to the +pole as well had the marking in the last picture, just as information.
If it is the Passenger seat, then it is likely to be the Seat Mat used to sense if the passenger seat is occupied. Used for the Airbag System and the Seat Belt Warning.
I have assumed, maybe incorrectly, that the charger needs needs to connect to the starter battery to draw from alternator, however if the split charge relay provides this, then that’s where I’ll connect, one of the functions of the EcoFlow Delta 2 battery is it can provide a boost charge to the starter battery (if flat) when required if connected, I’ll need to investigate if this feature is still applicable if connected via the relay under the seat, certainly make life a lot easie
Mine is connected to the ambient LED lights mounted in the lower plastic trim panels on the rear of the front seats, they appear to be missing on your panel. Lights come on when the door is opened.
