Rubber seals on drivers door displaced
Taf Powell
Taf Powell
Wandering Dood
Aberdeen
T6 Ocean 204 4Motion
In the recent freezing weather, the driver's door seal was pulled out by the ice build-up. The seal is a short curved piece that works between the door and the wheel arch. One of the retaining clips is embedded in the displaced seal and the other clips are in the door profile. The 2019 van is under extended warranty but my dealer - Clark Commercials Aberdeen - advises this fault isn't covered. My concern is that the seal, having been pulled out, will not be held firmly by the clips should I refit it. However someone in the service team suggests - as an alternative to taking it to the dealers for a replacement - I use a 'specialist' adhesive to hold it in place. This is a fairly attractive idea as the seal is in perfectly good nick.
I would appreciate advice on whether using a rubber adhesive to assure retention is a good idea. And what adhesive to use?
I would do two things.
1. Treat the rubber with Gummi pflege. This will ensure that it is less prone to becoming sticky - especially in cold weather.
2. Use a specialist rubber compound such as the 3m black weatherstrip adhesive to bond it back.
I used this for a similar problem (the rubber door seal) about a year ago and the piece is still in place .
The wheel arch rubbers are a really cheap part, can be bought individually or as a pair, get a new set and save the adhesive for another day.
Agree with Kureinp after fitting the new part treat with Gummi Pflege or silicone
Thank you both, Kurienp and Perfectos. Should I find a stock item would the clips be separate? One of the clips has come away with the seal rubber and looks broken.
Best
Taf
Best
Taf
Clips are included but check the actual product, (VW ones are supplied with clips & IMO would be useless without them)
there are loads of sellers on a well known auction site
edit just looked, “ vw T6 wheel arch seal”
the first product shows clips (DYOR though)
note they are handed left and right
The same happened to me, both front doors. Just replaced with original parts for 20/25€ for both.
OEM VW codes: 7H0837565A + 7H0837566A
Really helpful advice, thanks
I’ve had a similar issue with my door seal getting pulled out during cold weather, and I totally get the concern. In my case, I used a strong rubber adhesive that worked really well, but I made sure it was designed for automotive use, so it held up even in extreme conditions. The adhesive worked fine, but I also made sure to clean the surface before applying it. As for Mantaline, they specialize in automotive elastomeric solutions, and when I had an issue with my seals, they helped me find a tailored solution that kept everything secure. You might want to check with them for advice on adhesives too.
guys, what's your opinion about this???
The same happened to me. I was going to glue but rubber was undamaged so got these clips from amazon which worked wellScreenshot_20250131-122028.png
Trollhunter
Trollhunter
Trollhunter
Cloudbreak
GrumpyGranddad
G
westfalia
westfalia
Hillsiders
secret lemonade drinker
