Waxoyl or DiNitrol are the usual treatments. Wire brush and spray. Messy but easily done as DIY. Use disposable overalls as it gets everywhere. Used to do it on my Land Rover Defender. Had to do it annually but then everything was exposed, no underbody trays/protection.Hi all, took under tray off today and chassis / subframe is showing signs of rust has anybody had waxol treatment done ?
Any advice what to do would be welcome. Also can it be a diy job .
Hi Borris,I don't use Waxoyl anymore as I found that if doesn't last quite so well as Dinitrol. I have just done our latest van using Dintrol Corroheat 4010 Clear High Temperature Wax. It is easy to apply using the special applicator spray attachment. Warm the tins before hand and shake well. Mask off the brakes with a big plastic bag and avoid getting any on the exhaust. There's no real point in spraying the underfloor body shell as that's been galvanised dipped so just conscentrate on everything else. Anyway VW already appear to have treated the body pressings with there own wax product. I usually either run one end of the vehicle up onto portable ramps and after doing the underside, I drop it down and remove one wheel at a time to do each corner. Make sure it's properly propped before going anywhere near the underneath.
Hello Jeff,Hi Borris,
How much dintrol did you use ? Also did you use the aerosol cans or there applicator ?
Any photos Borris ?I don't use Waxoyl anymore as I found that if doesn't last quite so well as Dinitrol. I have just done our latest van using Dintrol Corroheat 4010 Clear High Temperature Wax. It is easy to apply using the special applicator spray attachment. Warm the tins before hand and shake well. Mask off the brakes with a big plastic bag and avoid getting any on the exhaust. There's no real point in spraying the underfloor body shell as that's been galvanised dipped so just conscentrate on everything else. Anyway VW already appear to have treated the body pressings with there own wax product. I usually either run one end of the vehicle up onto portable ramps and after doing the underside, I drop it down and remove one wheel at a time to do each corner. Make sure it's properly propped before going anywhere near the underneath.
Hello Trebor,Any photos Borris ?
I did wonder. I will take some snaps when IVery Nice Borris . Is that a Majic Carpet Ride ?
I did mean underneath though . How many panels do you remove ? I used to do this in the Olden Days with Land / Range Rovers but they were easier to get underneath!
