Was it difficult to drill out? Any tips? And did you manage to buy a replacement OK?No keys for the Safe. Had to drill out the lock. It was empty
Is it possible to buy a replacement lock?
No very straightforward to drill, never found a replacementWas it difficult to drill out? Any tips? And did you manage to buy a replacement OK?
Did you order one of these? I drilled out the lock (which was worryingly easy to do...); the only issue is the lock I've removed has a smaller body than any of the replacement ones at Unico (or EBay). So it might be a case of making the hole in the safe door bigger with a dremel, or seeing if I can source a small bodied lock. Would be interested to hear of anyone else's experience.I noticed Unico do a version of the cam lock with a combination lock, might be a better option than another key?
