Saucepans sliding..
Mrs Pins
Mrs Pins
Norfolk
Looking to buy
We bought a set of stacking pans called Kamp Cook. It includes a kettle.
The only problem we have found is that as they are telflon coated inside and out they slide when on the cooker!
The kettle is fine as it has a different bottom. I was almost scalded when the saucepan was beginning to boil.
Anyone else had a problem? I don't want to 'rough' the bottoms up as they were not cheap in the first place!
I think I may take them back to be honest!
Don't cook whilst driving!
Seriously though I think returning them is best
Hubby returned the pan set for a refund, wanted to give us a credit note as we had had them a while ( but not used) Managed to get some other stuff we needed instead. I wrote a letter to Kampa about the saucepans and the problems with them... the email was a pretty rubbish sorry we will tell our designers type of letter! It's put me off buying saucepans from them I must admit.
Yes, we had the same problem with Tefal pans. It's gets worse as the pans heat up too. We have persevered and now they are a bit worn they are a lot better but you still have to be careful. No one tells you this stuff!
One answer is to use pot clamps as used on small boat hobs.F
We have the tefal set you just need to be level.
DM
Johnboy
bob_summers
bob_summers
D
6K
kp64zl
kp64zl
secret lemonade drinker
