Alan
I have been putting off changing a slow puncture for 6 months on the van. Main reasons being, fearing having problem with wheel holding fast on hub, and using the scissor jack which has had some negative posts on the forum.
After a quick look in the hand book on the supplied jack I got started on loosening the wheel nuts.
Drove the motor forward and backwards aplining brake pressure ( as previously recommend by a forum member, thank you )
Jacked the offending wheel up, the jack performed above my expectations
Removed wheel nuts, mallet standing by I proceeded to pull off wheel.
Couldn't believe my luck, the wheel came off so easy inspite of heavy rust marks on the hub where the wheel mates, indicating the dreaded wheel stick
Spare put on, as with the kettle
Alan
Alan
