ElsieH
Hi,
I was wondering if anyone had a parts diagram for the rear seat belt latches and where they attach to the vehicle.
I was putting the bed down in my 2014 SE and when reaching for the strap to lower the backrest, stabbed my hand on something sharp. When I pulled it out, the door side seat belt latch came away in my hand. When shining a torch down, the kitchen side latch is retained by some rusted wires which are about to give way entirely. The latches appear to attach to the van by braided metal cables which have rusted through and I now have no working rear seat belts. The wires then connect into a silver metal part which also appears to be corroded.
I've booked the van in to the dealers but want to make sure that they order the correct parts as although they are a van centre, they don't sell these vehicles. To be honest, I'm absolutely gutted that something as critical as seatbelt restraints have completed corroded through after only 7 years and in an area where I can't see any water ingress. I'd seriously urge you all to check the mountings as the only indication I have is a small area of rust on the bottom of the seat cushion which isn't obvious unless you go looking.
Any ideas what could have caused this ?
