Selecting gear
Kencouceirovwc
Kencouceirovwc
Kenco
Cornwall
T5 SE 180
My 2014 t5 dsg when on a slope and you try to pull off you select drive then put you foot down the revs just drop and you have no power. The only way to move is to put it in neutral rev the engine then slam into drive it also happens in reverse. I’ve changed the oil have got Vw to run a diagnostic and it shows no fault. Has anyone heard of this problem
Never heard of that. On mine, Select D, release handbrake, vehicle will start moving forward even on quite steep slopes, as the anti-stall increases engine revs, then apply accelerator.
Have you tried resetting the DSG?
Post 15
Post in thread 'DSG' https://vwcaliforniaclub.com/threads/dsg.46798/post-608617
