T
Tipperdriver
Hi has anyone had problem with shower head tap broken off only my broken off and was in the sink I have drain all water from the van would it be moisture in tap and heavy frost caused this can any body help
I’d be surprised if a little bit of moisture has caused the tap to break. Other than that I’m not sure what help you are asking for?Hi has anyone had problem with shower head tap broken off only my broken off and was in the sink I have drain all water from the van would it be moisture in tap and heavy frost caused this can any body help
I did have the same issue last year where I hadn’t drained down as well as I might have thought, and the freezing water broke the tap off.
