Yes it has a 3pin plug on the kitchen unit behind the passenger seatI thought that your model already had a 150W inverter with a 3 pin plug located at the base of one of the front seats but I guess not. I would aim for the same approach as VW and install an inverter and plug similar to the later model Californias, adding some solar panels to top up the leisure batteries.
Messing with the existing plug on the kitchen unit, which is wired to work only with EHU, is asking for trouble.
Can you post a photo of the inside bottom of the front right hand seat?Yes it has a 3pin plug on the kitchen unit behind the passenger seat
Not the same thing. There may be a plug at the base of the drivers seat, assuming RHD, that allows you to plug in off EHU. This is the “inverter” plug and on the older Cali’s can power devices up to 150W.Yes it has a 3pin plug on the kitchen unit behind the passenger seat
On the T5/5.1 the 150w inverter socket is on the base of the B pillar directly below the Mains socket on the end of the kitchen unit. It has a black cover flap that you lift up to access the socket. It is not a 3 pin UK mains socket.Can you post a photo of the inside bottom of the front right hand seat?
