Tompoole
ok, so, had issue with van not starting. VW had it MON TUEs and found no fault.
today ive been out and had a drive and bought a ring battery charger and monitor...... I checked van after run and it showed battery needs replacing ,battery test shows 490amps and 72% advices to replace battery at these readings...... monitor shows battery 80% charged and 12.4v this after vw have said its ok and been on charge since tues and a good run today......
what should I do ? wait for it to fail again and go through same procedure of vw insisting no issue , or just replace at my cost ?
