Hi, go to control panel and try step from there.My step has stopped working. Turned off electric, but step stays in. Any ideas?
Had mine replaced due to same issue apparently a faulty batch from Thule. Also check the button on the dash. Mine would only close with a nudge.My step has stopped working. Turned off electric, but step stays in. Any ideas?
Well it will be silky smooth when replaced.Looks like my will need replacing. Bonkers. Brand new van.
This may not be your problem but initially we over stocked the the fridge ie no circulation, temp set to 2 and now all ok also night mode works well.Exactly the same problems I have. Must be an easy fix for the step. Wish fridge temperature could be adjusted to stopping freezing the food. Everything else seems to be ok since it was delivered in July 2021.
Sadly our step is not working either. Checked the manuals but no joy there … disappointing in a new van with little use due to winter away with family …. Any suggestions welcome please ??I’ll be removing mine, never use it, just adds weight and reduces ground clearance.
Hopefully the dash won’t light up like a Christmas tree after removal.
If the step isn’t working you could try and reset. Turn off the main red isolation switch in the electrical cupboard, then locate the ‘magic’ blue connector located on the left hand side under the dashboard. Look up from the footwell. Unplug this and wait a minute. Plug back in, turn on red isolation switch and see if the steps working.Sadly our step is not working either. Checked the manuals but no joy there … disappointing in a new van with little use due to winter away with family …. Any suggestions welcome please ??
Like The Yorkshireman, I had issues from handover ie April 2021 fortunately i pointed this out at the time and one was ordered, however it took 3 months to arrive so had to nudge it into place at the same time as shutting the door you soon get the knack. The new one arrived and was fitted and I have not had a problem since.We've had issues with our step since day one. The reset has worked every time so far, probably had to do it 10-12 times. Getting really tedious. I would put my money on a software malfunction. So many people with same issue surely there should be a recall. Its very disappointing on what is suposed to be a fairly high end product.
Well that sounds interesting. Our steps are not working correctly. Steps were already replaced once year ago and never worked 100%. "They live their own life" as we used to say.Interesting info here - new step and new software. https://www.grandcali.com/trittstufen-update-massnahme-3419/
