Steve Gray
Hi all.
Due to family commitment we have been unable to bet out in the 600 for about 12 months the van is just 3 years old we have had it from new and it has covered 6000 miles. It has just been in my local VW Commercial van centre for a cambelt & water pump change and MOT. On our first trip out this year we had travelled 3hours and stopped to fill with diesel on resuming a flashing amber coil warning light came on the dash. I pulled over stoped the van switch back on light went off. Resumed the journey amber engine management light came on then flashing coil light again followed by lack of power on hills. Managed to nurse the van to our destination I called VW assist which is the AA they came out plugged into the OBD port looked at fault codes reset it and said it should be fine now. In 10 days time we travel back and I guess I will see if it is ok?? Below are the fault report from the AA.
Patrol found the following fault code/s:System : Engine management 1 - VEL / Engine management EDC Delphi DCM 6.2 UDS Status 22D300 - Turbocharger solenoid valve Turbine inlet. Error Message : Component stuck closed. Sporadic fault. Status 22D500 - Turbocharger turbine position sensor. Error Message : Signal improbable. Sporadic fault. Status 203B00 - AdBlue tank level sensor. Error Message : Signal improbable. Sporadic fault.Had a stuck solenoidDid a resetEngine Oil Level Ok. Coolant Level Ok.
Question 1. Has anyone ever experienced this and how did you rectify it?
Question 2. Does adblu go off? I have a tank full in the van which has been in 12 months should this be drained off and refilled with new adblu, could this cause engine management issues as it is mentioned in the AA report.
Any advice would be greatly received and sorry for the long winded post.
