Strut top location
Interestingly, the VW main dealer I bought mine from in Germany was offering (on VW headed paper) to fit both B14s and 20” wheels on new Calis.
I asked the dealer about the VW springs and they said they didn’t recommend fitting them in conjunction with 20s.
Guessing this could be because they deemed the ride a little harsh with that combination(?) or because they were charging loads more €€ for the Bilsteins
Fair play. The plot thickens on this can of worms.
Ideally I'd like to install my B14's but clearly I don't want to invalidate any warranty.
....... I knew I should have bought one pre 2017, cheaper road tax too :confused:
An excerpt from the warranty manual. As already said we have to take pictures when submiting warranty claims so if a modification can cause a failure of a related component it will be rejected.
See comment below, Air would give you the best of both worlds me thinks, but as you say £££ and back to the warranty issue.
Worth checking but I think I read that VB air suspension is a VW approved modification and thus doesn’t present warranty issues. There’s just the issue of cost instead. Thick end of £5k I believe.
EDIT: now I can’t find the article, just that VB are a VW ‘Premium Partner’ so maybe I’m wrong or that’s not the case anymore.
Correct, provided VB suspension is fitted by an accredited supplier it does not affect the VW warranty.
BuieBodach
Docmark
Docmark
Docmark
R
5K
testpilottimmy
T
