T4 display reset? 1991
V
Vanhelen
Manchester
T4 PopTop
So 1 week of owning and I thought I'd test the fridge out today. Seems not to work...however now my control panel isn't responding to any buttkon press including turning off the not working fridge. Stuck on this whatever I press. Is it possible to reset it?IMG_20210418_193144.jpg
To the best of my knowledge there isn’t an official ’reset’ procedure for the Westfalia Central Electronics, it’s a much simpler affair than in the current California’s. My suggestion would be to pull fuses 1 and 6 behind the drivers seat. Give it a moment then replace them. The display will probably look a bit odd but if you start the engine for a few moments everything should reset.
