Malrider
Have 96 T4 2.5 Petrol Camper.....thought I had a problem with a plug( drop in power in3rd/4th gear) so I have replaced all pugs, Leads, Coil also sent away and got ECU tested, found MAF Senor fault/repaired ..... after 2 mechanic and $2000 problem still exists...!
Problem is .....Camper starts fine, once you get into 3rd gear and under load there is a loss of power similar to a fuel blockage or faulty pug/lead and at time backfires,
I am thinking that may be Fuel Injectors, or Fuel problems..?
Looking for any Help.....this doing My head in ..!!! posted below thought I would explain better on new thread.
