T6.1 Near side fog light
Marc S
Alcester
T6.1 Ocean 204
I hit a deer a couple of days ago no major visible damage other than nearside front foglight bulb failure illuminated immediately, on inspection I can see the light fitting is pushed back about 5mm so barely noticeable. I will have a closer look this weekend but just asking in advance how difficult this might be to access and replace the bulb, if indeed it is just the bulb gone, I think they were on at the time so were probably hot. I've previously noticed they are not as bright white as the headlamps so presume they are halogen and not LED. Any advice welcome ?
Easy access. Rotate wheel out of the way and you'll see an access panel on the leading edge of the wheel liner around same height as the foglight.
Yeah just as Corradobrit says. Should you need to replace the bulb they are H11 fitment....just done mine and it's a simple job.
