Mattsv
Like a few others, I learnt the hard way this weekend that leaving anything on the ledge below where the bed hinges, results in the plastic bracket snapping.
I managed to source a new bracket from Campervantastic which arrived very quickly and only cost £8 plus delivery. Upper Bed Hinges
Hardest bit was drilling out the old rivet - needed a bit of persuading but not too bad. Slid the old clip out (undid the torx bolt on the bracket to make it easier) and fixed the new bracket using a cabinet joining bolt rather than a rivet.
Straight forward job, no need to remove pop top at all. Left a couple of tiny marks on the frame but no one will ever see them under the mattress. Might have been covered under warranty easy enough job to DIY - if you can drill out a rivet then it is easy to do
