N
normnortonocean
I have a 2020 T6.1 Coast. You would think that by now I have got the hang of the electrical systems for the rear cabin when camping, but several things still defeat me. I write in the hope that others who are brighter than me have solved the problems, or they agree these are faults and I just live with it!
The cabin heater cannot be controlled properly. I have complained to my supplying dealer but they cannot fix it. When you go into the rear cabin control panel for 'continuous' heating it displays a level for adjustment, but it won't work.You have to switch on the ignition, got to 'operating', set a level between 00 and 10, switch off the ignition, back to 'continuous' and the new selected level is shown. A pain just to make it warmer.
And what is the heating 'level' anyway, is it thermostatically controlled? The higher numbers seem to make the cabin warmer, so why is there not a cabin temperature readout? Mine seems to show the outside temperature.
The rear lights must have a mind of their own as they defy any attempt at control. Open the rear door during the day and they stay on forever, why? Twice I have driven away from a camp and they have stayed on - the control panel won't work while you are driving, I had to stop, turn off the engine, turn off the rear lights, then set off again. When camping I try and press the individual light buttons and they won't change, well only the centre one over the hob will work. You have to go to the control panel and select 'turn off all'. Then back to the hob centre one, press to turn that on and find your way to bed. Madness!
Sit in the front seat when turned around and try to use the overhead light to read a book and it quickly goes off, unless you leave the ignition on, which I assume is unwise for battery demand. I have to use a LED head torch. Turn the radio on and it goes off after 30 minutes, so expect to press it half a dozen times if you would like to listener the evening, or take a battery portable radio.
I think the electrical systems programming for the heating, the lights and radio is either completely defective or designed by some lunatic committee.
