T6 Control Panel Generator Battery Symbol Blinking
W
Wild Rover
Uk
T6 Ocean 199
After installing a new Renogy electrical system in my Ocean, solar panels, combined MPPT & DC to DC charge controller with 2x100Ah lithium smart batteries, the G/Battery symbol on the bottom right of the display blinks until reset.
The fault code I get is 7001, which corresponds to loss of D+ power. I can reset it, by holding down the return button on the display, but it returns after a while (usually a few hours).
I think it may be a result of the lithium batteries intermittently disconnecting briefly as part of their self monitoring, but I’m not sure, it’s a guess.
The split charge relay was removed as part of the modification.
Does anybody know how to stop it doing this. Everything else seems to be working as intended.
Hi,
Did you find a solution?
I have exactly the same issue. The split load charger is still connected; however, the fault seems to be triggered by solar charging.
Thanks.
