Temperature sensor
jeff
jeff
Home is where you park it !
Newbury
T5 SE 174
Hi does any know where the auxiliary temperature sensor is located. Also a part no would be handy is it a diy job or will it need a dealer to reset the new one with diagnoseit machine .
The External Temperature Sensor is located external underneath the vehicle, in fact underneath the position of the kitchen unit, just forward of the Dirty Water tank drain.
See enclosed diagram, 14 is the connector for the Sensor.
http://www.oemepc.com/vw/part_singl...972/subcategory/972090/part_id/3707698/lang/e
This might be the temperature sensor required.
https://www.ebay.co.uk/b/External-T...tyle=Bus&MEngine=2461ccm 174HP 128KW (Diesel)
https://www.ebay.co.uk/b/External-Temperature-Sensors/173863?&maspect=contextType:CAR_AND_TRUCK&MCar Make=VW&MModel=Transporter/Caravelle&MCars Year=2008&MVariant=MK V [2003-2015] Bus&MPlat_Gen=MK V&MCars Type=2.5 TDI&MBodyStyle=Bus&MEngine=2461ccm 174HP 128KW (Diesel)
Thanks will take a look hopefully just unplug the old one and swap for new one as showing faulty on central control unit.
