Try out: PlastiDip/Foliatec
sapto
sapto
Central Switzerland
T5 SE 130
I wanted to try to "plastidip" the badges on the back of my Cali. It worked okay, so maybe I keep it.
Never seen this , does it stay on for long?
How did those two small holes did come on your rear door?
Do you want me to edit the title ? Don't know of you are able to , seems you forgot to type a "L"
When i saw the titlle in the list was thinking about food....:D Pasti ....pasta
Don't change the title PastiDip sounds much tastier.
Hihi:) Thank you, I changed it although Pasta sounds good to me.
I have to test this plastic thing (washing might be a problem). It is easy to remove: there are a lot of videos on youtube, where they "sprayed" a lot more than some letters.
These 2 small holes :( The former owner used to have the original bike rack and there are 6 "marks" on my back (top, middle and bottom) as a result of heavy bikes(?).
One day I get it fixed.
I have used it loads, it's quite hard wearing and will stand up to jet wash straight on. The edges can eventually lift but it's simple to peel off and replace.
I used it for my wing mirrors and peeled it off again easily. Important to spray on the recommended (4 I guess) "layers" as it is easier to remove.
