Two seat rear bench
capt kirk
capt kirk
surrey hampshire borders
Hi guys
Has anyone got an assembly drawing of the rear ocean bench, mine has got stuck and want to see if the link on the cupboard end caster can be got at. Currently at honeyfest with no downstairs bed.
Cheers in anticipation. Ive looked in vip section but cant see anything relevent.
Kirk
This should help...
Pretty sure the bench seat is the same on T5, 5.1, 6 and probably 6.1 too
What a fine fellow you are. Bit to involved to get at here but when i get home first job on my list. I will follow up on results.
Thanks again
Kirk out
Just thought you might like to see the issue, rear lock foot jammed solid. No amount pf rock jiggling or brut force would shift it. With the guts of the seat removed i issolated the issue to one rear foot and with an endoscope down the rail found this……. A floating stop with no screw in it. And no screw found in the track so dont know how long its been like that. So just reassembled it all and still jammed but that was because i put the wheel on back to front so the foot couldn't move. All fixed now, happy bunny……
Thanks for all your help.
