Rear Bench seat
Cubby
Cubby
Cardiff
T6 Ocean 199
Hi all, ive been trying to get my rear bench seat to go right back and have found what looks like to be a stopper on the left hand floor rail wardrobe side, is it possible for this to be adjusted as to be able to get the tear bench seat to go back as fare as possible.
cheers
Yes. There’s one in the front too which can be removed to create more space for carting furniture etc.
Just make sure you don’t crash the bench into the rear shelf when sliding it back because there’s nothing stopping it.
cheers
There are previous threads on this subject. On the near side rail behind the bench seat, if you look into the channel of the rail through the rubber strips you will find a large flat headed screw. If you undo the screw slightly you can move it back to your desired position. It is connected to a lozenge shaped piece of metal that can removed completely if you wish. It is quite tricky to get it out but if you persevere GENTLY it will come out.
Hi many thanks for the quick reply
Stewart MCG
dfps
Barryjm
Barryjm
D
holliers
holliers
L
T6 CFO
T6 CFO
Morganic
6K
homerorchid
homerorchid
