Calincolnshire
Does anyone know what tyre pressure you run the M&S tyres at. It does not have the 215/60R17 pressures on the sticker in the door . I have set them the same as the 235 size pressure but I think they should be around the 50psi range, as I found 52 front and 48 rear (lightly loaded) from the T4/5 forum but there are discrepancies to on the other tyre sizes that i do have listed on my Cali ,especially on the rear and I guess this is due to the extra weight in the back.
http://www.vwt4forum.co.uk/showthread.php?t=233590
Not been anywhere in it since the wheel swap but would like the correct pressures before I venture out, so any help would be much appreciated.
