CALROE1
Had our first night in Cali last night slept on top bed now see why people use toppers we are seeking help which are best toppers and value for money thanks Sheila and Michael
Bleur fleur said:I use a thin IKEA topper and a fake sheepskin type mattress cover from Dunelm and a jersey fitted sheet. Very comfortable and I can leave it in place when lowering the roof.
comfortz said:Hi Folks,
We've disptached quite a few 2" memory foam replacement roof mattresses out this last two weeks - it'd be good to see how you guys get on with themand don't forget the photos!
Cheers
Nick
mike&agnes said:Calikev: am I correct in understanding that you have used the original VW upstairs mattress PLUS an upstairs Zonesleep and closed the roof without any damage to roof or the hydraulics in over 12months use? I'm not sure if I have the nerve to try this, I hear that a bent roof is an expensive repair!!
As an alternative option, I was measuring up today and found that the original VW mattress is 5 CM thick. The Zonesleep is approx. 3CM thick plus my original memory foam topper (which I no longer use) is 2CM. My thought is to use these two together ( ie same total thickness as the VW mattress) and dump the original VW mattress. This would mean that I could close the roof with complete confidence and save significant valuable boot space.
Obviously this set up needs checking out for comfort over a few days actual use, but we have been very impressed with the Zone sleep, so I think it should work.
Has anyone else tried this or similar configuration? Any thoughts on how it might work?
