snowy55
By the way what is VWCS?
Volkswagen Customer Services
If compression was down the trick in my "fix it myself" days was to trickle some oil down the bore to see if compression increased. If it did then it was worn bores/rings, if it didn't it was the valves.It may be valve stem oil Seals??
Thanks snowyVolkswagen Customer Services
ThanksIt may be valve stem oil Seals??
ThanksSee first post, and reference to VW Technical Report.
http://www.vwt4forum.co.uk/showthread.php?t=446408
