I was asked about tips on setting up the galli ||| rsv awning on the ocean. I Agee using the tunnel does cause problems. My solution after one use is recorded here. Am open to improvements.
1 I wanted to be able to use wind out awning to tension tunnel roof to minimise water pooling. So cut the 6 mm to 6 mm kaydor strip to the size of the awning slot so that it allowed the awing to be fully closed then to act as a guide cut the figure of 8 hard plastic bars to be equal to the full length of the tunnel ( right to the end of the black webbing front and back )
2 wind out awning 30cms to allow tension to be created when wound back in once main tent is up
3 drivers door is not used when awning is connected so tunnel is fixed to aline with door edge Pegged to ground and the tent beam 92 cms out from edge of van. Note if you have the protective ground sheet this point is used as the starting point of placing it in position. A peg in base of galli at this point useful
4 fit kador then connect the figure of 8 to kador and galli 6mm piping.
5 I would start to inflate rear beam then support with storm straps loosely working from rear inflate beams eusuring they are on their Velcro spots. Go inside to reposition and get things like ground sheet taut.
6 the tunnel should line up with the rear of the van but still allow easy opening of tailgate.
7 the rest is up to you. Note my van is lowered 30 mm. Unless the tunnel roof is tensioned the hard plastic figure of 8 catches on the top of the van sliding door as it opens.
Hope this and the pictures help Galli ||| rsv owners.
regards Marcus
