chrisswash
- Messages
- 13
I am having problems with the tap in my T5 california. Does anyone know where i can get a replacement.
thanks
chris
thanks
chris
Derrick said:Hi Mark
I am having intermittent problems with my tap not working - I think it must be a sticky microswitch. As you have had a chance to take one apart, do you think there is any simple fix - eg a squirt of silicone spray?
Derrick
Hi MarkYes... I had the same problem.
Spare tap from VW... At the time about £35 I think and the advantage was it was in the next day.
About 30 minutes for me to fit. Easy job if a little fiddly.
It is also possible to fix the micro switch, it's an open construction inside the moving part of the tap lever. The cover can be levered off to the side. I found that the spring steel part in mine had bent slightly, fixed it and now keep it as a spare.
Rgds
Mark
Looking at this diagram, it seems as if it is a push fit.Hi Mark
Can you give any advice on fitting a new tap. Do you hav to remove the sink/cooker unit?
Regards
David
Thanks Calikev, that's a relief. Do you know if there are any diagrams or videos available? I've had a look on youtube but not much there!No you don't need to remove the sink
Thanks but this seems to be a different tap to the one on the T5.Looking at this diagram, it seems as if it is a push fit.
http://www.oemepc.com/vw/part_singl.../068/subcategory/68020/part_id/3707645/lang/e
the micro switch in the tap is playing up and stops working after a few uses. i can unplug the supply cable to the switch in the tap and short out the 12v to the switch and the pump runs fine so i know thats ok. any suggestions would be appreciated as i am due to touring on the 17 july and need to sort this out.
