Ben Herrick
Hi,
I had noticed that the LED light strip above the kitchen cupboards was flickering or part of it not working at all (for example, the part of the strip adjacent the sink and fridge might work but the middle part adjacent the hobs didn't so I was left with a dark spot). The issue was also intermittent so it didn't bother my that much, however, as my van is still under warranty, I took it to VW for fixing. All VW did was replace the LED strip so only time will tell if that fixed it (so far so good) but I was curious if anyone else had experienced this and might know of a solution if the problem is to return?
Unfortunately, I don't have any photos or videos showing the defect which was half the problem when explaining the issue to VW - typically when I went to check the light, everything worked!
Any help or advice would be much appreciated.
