MattBW
Here to help
Did some investigating with a volt meter today.
As a few people have experienced the waeco can cut out (battery protection) even on a full battery a little too early, many suggested it was voltage drop off across the cable. I was always reluctant to set it to low as that could in theory could damage the battery.
Using a volt meter I discovered that even on medium battery protection the fridge was cutting out around 12.3/12.4v. on medium t should cut out much lower.
With it set to low my fridge is working fine and the battery is still sat at 12.4v, 12.3 when the compressor is running.
Looks like a direct battery connection is a must as many have recommended but it does make me wonder if it could be the individual connection itself. I also wonder if the waeco manual is incorrect or the protection circuit faulty .
For now I'll run on low battery protection with a voltage alarm plugged into the leisure battery elsewhere.
